What bike do I have
Ok new issue. Son stopped the ATV and as he sat there gas started flowing out the tub at the Bottom of the carberator and I could not get it stopped. Finally it stopped on its own. Any ideas for a non mechanic here? Thanks in advance
Stuck float needle in the carb is your leak problem. Often a tiny piece of debris gets stuck between the needle and seat.
Smaller front sprocket or larger rear sprocket or both will lower top speed and increase acceleration from a stop.
thanks a a ton man. I took the carb apart and cleaned it with brake cleaner (only thing I had handy) dried it and back up and running.
Now even with the throttle turned all the way in to the slowest position it has power but I find if he goes with the throttle push all the time it still goes too fast. Is there anything special I needed to do to the carb when I put it back together that would cause the bike to still be fast even if the throttle is set almost all the way off on the handle Bar?
thanks
