125cc Rear Brakes Not Functional
Old Sep 15, 2019 | 03:29 PM
ItsPotter's Avatar
Exclamation 125cc Rear Brakes Not Functional
Hi all,
I recently needed to replace the brake pads on my coolster 125cc atv rear brakes. Normally you would no have to issues replacing the pads because there is a simple allen bolt to remove them , but our bolt was seized so we needed to remove the caliper from the frame and brake pump and use a vice to remove the pads. Anyways, the pads are replaced but now the brakes are not working. The rear brake light does not illuminate when pressed, and the caliper doesn't move. We tried adding more brake fluid, bleeding the brakes (although i'm not sure we did it correctly), name it we probably tried it. Anyways, we are at a loss and really could use your help. Thank You!!
NFrontofU
Oct 5, 2004 06:03 PM
02BAJA
Apr 28, 2003 08:41 PM
weedy
Sep 15, 2000 07:19 AM
