Wiring diagram?
Old Apr 21, 2021 | 02:45 PM
Shelby Cameron's Avatar
Default Wiring diagram?
I am looking for a simple way to to get my Roketta up and running. I know the motor runs and I have a new CDI box, Regulator and solinoid. I'm not getting spark. Can you direct me to a great place to find easy wiring diagrams for my little atv.
Old Apr 22, 2021 | 02:33 AM
Take a look at the help diagnose stator sticky in the engines section of this forum. If it is the usual AC CDI, the ignition is completely separate from the rest of the wiring, so any generic diagram will apply, although the wiring colours may differ.
Old Sep 9, 2021 | 08:26 PM
Jercal27's Avatar
Well all the diagrams are different than what I have y I dont know my stator has 2 yellow,green ,red black ,blue white, cdi has green blackwhite,yellowblack,red bluewhite..key switch has red black green and white black and handle bar run off lights and start button is blue,redwhite,brown,green,yellow,blackwhite and black two small from solenoid are yellow and green I CNN seem to get everything to work except the start button
Old Sep 11, 2021 | 04:13 AM
Take a look at this diagram then, seems closer. Don't get hung up on colours, note a white wire and a yellow is shown going from alternator to reg, does exactly the same job as the two yellows on your set up. As long as the same wire goes from start button to solenoid the actual colour doesn't matter. Red will be linked to black, with ignition on, in the ignition switch. What is marked as safety switch is usually a brake light switch.
Gale Richter
Technical and How-To Articles
Apr 21, 2017 12:52 PM
jennifer_rose_82
Jan 26, 2008 08:21 PM
