Identity crisis
Old Jul 19, 2023 | 03:57 AM
Jav's Avatar
Jav
Default Identity crisis
Any help identifying this please
Quad purchased while I was in Pakistan , I believe it to be a Chinese built 250cc
Old Jul 20, 2023 | 02:26 AM
Engine says Zongshen so I would assume that is what it is, unless proved otherwise. Google doesn't throw a Zongshen bike with those plastics up, but they did utility 250s so probably changed the plastics a bit, depending on model year, Honda did with the Recon. Rear axle looks like a Yamaha copy, and engine will be a Honda clone.
Old Jul 20, 2023 | 03:26 PM
Jav's Avatar
Jav
Thank You,,
I person I got it from told me he was told it was a 250cc
problem is over in Pakistan very little is known about ATV's I'm not really a bike person myself so I got it rather than car (storage etc and fact its only used 6/8eks in year)
had all whirring stripped as there were joints with insulation tape everywhere, all re-done soldered with heat sink end to end
just need to replace the speedo meter and rear speed sensor. Also derive shaft rubber housing
I have no idea about what the parts are called or where other than ebay I might be able to buy parts for it
any pointers will be much appreciated
Old Jul 21, 2023 | 02:34 AM
Drive shaft rubber housing may be a problem as it could be Zongshen only. However, could be Yamaha as the axle is a lot like a Yam. The speedo may be fitted to other Chinese bikes but would be difficult to source. The display is working in the picture so why replace it? Speed sensor will be a unit fitted to many bikes but sourcing a replacement will be problematic, as Chinese spares seem to be sold by showing a picture, with a list of machines the vendor knows it will fit, often with dimensions, and leaving the buyer to work out if it will fit their machine. If both speedo and sender are toast, a "work around" using a universal cycle speedo may be the easiest option.
Old Jul 21, 2023 | 09:11 AM
Jav's Avatar
Jav
thanks again
digital display has stopped working, when it did work , it would only show 0000 . ( not that MPH is a issue over there. Still better to know how fast your traveling thsn not)
Might be idea just replace it all with your suggested work around ( didn't think to take the sencor off and bring it back to UK with me )
