Timing Voltage low cause loss of spark?
Old Aug 31, 2023 | 02:11 PM
restes1989's Avatar
Default Timing Voltage low cause loss of spark?
I went through the common spark trouble shooting 5 pin CDI that you see on here often. TLDR: only measured 16ohms from timing trigger pin to ground, .143 VAC timing trigger on cranking, only seeing fractions of a volt spikes from ignition coil pin to ground.
Here's my results from the diagnostic steps:
Assuming the answer is yes, the first thing to do is eliminate all kill switches and kill switch wiring:
Method 1) Unplug the CDI and remove the kill switch pin in the CDI connector on the wiring harness. The pin is held in with a spring tab on the pin itself. You'll have to probe into the connector and push this tab in order to extract the pin. Plug the CDI back in (kill switch wire dangling) and see if you have spark. Nope
Method 2) Unplug the CDI. Turn on the ignition switch and set all kill switches to the run position. Use a meter to measure resistance in of the kill switch pin in the wiring harness connector to engine/frame ground. If the reistance is infinite on the 100K ohm scale then your kill switches/kill switch wiring are OK. If you measure zero ohms then you have a kill switch/wiring issue. Was good
The other inputs your CDI needs to make spark are AC Ignition Power, and the Trigger signal. Do the following:
1) Unplug the CDI. In the wiring connector measure the resistance of the AC Ignition Power pin to the Ground pin. You should see 400 ohms or so. What do you measure? 332 ohms
2) Measure the resistance of the Timing/trigger pin to the ground pin. You should measure 150 ohms or so. What do you measure? ONLY 16 OHMS
3) Leave the CDI unplugged. Set your meter to measure AC volts on the 100 volt scale. Measure the voltage on the AC Ignition Power pin to the ground pin while cranking the engine. You should see 40 to 80 volts AC while the engine is cranking. What do you measure? 45v
4) Set your meter to measure AC volts on the lowest scale you have. Ideally this would be 2 volts but many meters don't go down this low. In that case use the lowest scale you have. Measure the voltage on the Timing Trigger pin to the Ground pin while cranking the engine. You should 0.2 t0 0.4 volts AC. What do you measure? ONLY .143v
Now for measuring the output side of the CDI:
A) Leave the CDI unplugged. In the CDI wiring connector measure the resistance of the Ignition Coil pin to the ground pin. You should measure less than 1 ohm (but not zero ohms). What do you measure? 0.6 ohm
B) Plug the CDI back in. Set your meter to measure AC volts on the 20 volt scale. Set all kill switches to the run position. Crank the engine while measuring the voltage on the Igntition Coil pin to ground. Poke through the insulation of the wire if you can't probe the connector.
What you should see is a lot of random numbers with lots of zero values as well. This is because the meter may catch all or part of the spark event voltage, with a lot of nothing in between. Describe what you see. Only a spike of 0.15-0.25v at beginning and end of cranking (I figure this could be a peculiarity of my multimeter)
Old Sep 1, 2023 | 02:17 AM
Well, it looks like your "timing trigger" coil is shot. Worth checking the coil where the stator plugs into the loom, to be sure it isn't a broken wire between there and CDI which is causing the low voltage, but low ohms would indicate it is a shorted trigger coil. These days everyone seems to buy a new stator rather than just change the timing pulse coil. I guess it depends on cost and availability, Honda clone stators are cheap, some less common engine types may not be.
Old Sep 2, 2023 | 08:32 AM
restes1989's Avatar
Thanks for the reply. It seemed that was the case but just an odd item to fail randomly. The thing was running before I parked it a few weeks and it lost spark. I just ordered a whole wiring harness and stator and everything for $30 :/
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Jeff Hann
Oct 18, 2018 07:10 PM
wls1012
Feb 11, 2018 02:59 AM
thisguy
Jun 16, 2013 09:36 AM
bc0508
Feb 18, 2013 08:18 PM
