Front Shock Preload & Bottoming Out
Preload is not meant to compensate for valving, it is meant for setting rider/bike weight and sag and will most likely have little effect on bottoming and significantly affect ride harshness.
If you are having a problem bottoming, send them off to be revalved (if they're rebuildable) or save some money and do it yourself if you have the proper tools. If not, check to see if TCS can do anything for you.
More than likely there is a vast improvement to be made over stock.
