shock and throttle help
Old Sep 1, 2003 | 09:45 PM
matt2490's Avatar
Default shock and throttle help
number 1, what does it take to rebuild a shock? can you do it yourself or do you have to send it in somewhere? and also how much will this cost.
number 2, how hard is it to put on a motion pro twist throttle? if you get the kit is it everthing you need? thanks. matt
Old Sep 2, 2003 | 02:58 PM
Mike330R's Avatar
It's best to take the shock to a place and have them do it. If it's just a rebuild they change the oil and seals. Usually around $100.00.
The twist is simple to install and it usually has directions. Should be everything you need.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
sleepyva
Sep 2, 2015 06:32 PM
Polarisman1123
Aug 13, 2015 08:13 AM
Mssarabug
Aug 10, 2015 12:56 PM
