Need help with rim size
Old Feb 22, 2004 | 10:57 AM
Shav0's Avatar
Default Need help with rim size
I am looking to get new rims for my blaster. The stock rear ones are 8*8, and the front ones are 10*5.5
Where can I get 9*5.5 size rims for my front?
Old Feb 23, 2004 | 12:59 PM
newbeatle's Avatar
I no nothing about the Blasters, but most sport quads run a 10" front wheel, to clear the disk brake assembly... if the Blasters have small enough brakes to fit a 9" wheel over the assembly, I'd think that the wheel would be widely available...If they aren't widely available, I'd suspect that a 9" rim won't fit over the brakes...
Old Feb 24, 2004 | 10:08 PM
PmanX8's Avatar
I agree with newbeatle... check the brakes first. altho you have a 00 blaster, that has Drum-fronts right? because i have the disks on my 03 and there is almost no clearence between the inner rim and the disk-protector plate thing. its better to be safe than sorry.
another point ill make, is that its much easier to find front tires for a 10 inch wheel than a 9 inch, JMO good luck!
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
