Replacing cv boots
Old Mar 28, 2004 | 11:30 PM
countryboy1's Avatar
Default Replacing cv boots
How hard is it to replace the cv boots on a '02 700 sportsman on the back? Need any special tools? How long does it take?
Old Apr 1, 2004 | 07:01 AM
tack's Avatar
It's not too hard to do. the only special tool is the boot clamp pliers. I made mine out of large needlenose pliers by grinding little hooks in the tips. The procedure is easy. Pull the inner boot off at the big end and pull it down to expose the cv joint. Inside the gearbox hub there is a large internal snap ring that keeps the joint from falling off. remove it and the axle assembly will slide right out. The rest is pretty evident. Try a search under google for polaris cv boot replacement, I found a step by step a while back. Good luck.
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
