How do I rebuild my $#%@ shock???
Old Sep 14, 1999 | 04:37 PM
Fast91Mojave's Avatar
I really need to rebuild my Rear shock on my 91 Mojave. I would appreciate any info that anyone could post about it. Specifically, what it consists of, changing gaskets and what else? How much will it cost me? If anyone knows where any how to tech articles are, PLEASE tell me! My shock is dead, my rear tires are all over the place causing me to lose major traction!! thanks!
Old Sep 18, 1999 | 10:30 PM
kevhog's Avatar
Unless you own a motorcycle shop, I wouldn't mess with it. It has Nitrogen in it, set at about 250 psi. If you can get it out with out injuring your self, how do you plan on getting it back in? Or getting nitrogen, period? Any major motorcycle repair facility can recharge it for you, or any race shop can totally rebuild it for you. Call Race-Tech, or Pro-circuit, they do all that stuff.
Old Sep 19, 1999 | 06:20 PM
86atc250r's Avatar
I rebuilt mine last year, it wasn't too bad, it doesn't sound like mine was as bad as yours, but all I did was discharge the nitrogen from the schrader valve, the valve will regulate the amount of nitrogen that can come out, so it isn't really dangerous (but always exercise caution). I bled all the old oil out, replaced it with a little heavier viscosity synthetic shock oil, make sure you get all the air out, I mean all of it, it is a pain, but can be done, you may have to replace the spring as well, and reassemble it, and have it recharged (I had mine done locally for $5). As long as nothing is worn out on the inside of the shock body, that's all there is to it. If it's internals are worn out, I would send it off to one of the racing specialty places and have it revalved and rebuilt, not as expensive as a new one.
Gabe
'86ATC250R
'86ATC350X
'00TRX400EX
Old Sep 26, 1999 | 01:42 PM
JD250R's Avatar
fast91mojave- Your rear shock can't be rebuilt because you can't take the top of the shock body off because it is welded on. The 1987 Mojave rear shocks can be rebuilt, but thats the only ones.
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
