painting a muffler
Old Oct 31, 1999 | 10:23 PM
bigmanMH's Avatar
has anyone painted a muffler and if so what was used and has it held up.
Old Nov 1, 1999 | 03:03 AM
scavanau's Avatar
Look for a spray paint labeled "high heat".
Should be easy to find in flat black. Unless you want to get fancy and use an engine enamel...
Properly applied to a clean surface, either one will work nicely. We use these at work for painting our industrial boilers.
Old Nov 1, 1999 | 10:35 AM
Tree Farmer's Avatar
Faced with surface corrosion on a 12-year-old muffler, I approached the auto supply store parts counterman with the problem, can of engine enamel in my hand.
"If it's rusty, forget about it," the man said.
What does he know?
Quite a lot, actually. Didn't work with casual wire-brushing as the only surface preparation.
I believe "scanvanau" when he says, "Properly applied to a clean surface, either one [high-temp or engine enamel] will work nicely," with emphasis on CLEAN SURFACE.
Good luck.
Tree Farmer
Old Nov 1, 1999 | 01:31 PM
Guest
Guest
Posts: n/a
bigmanMH,
Altho the appropriate forum for this post was"Other Atv Topics", we have left it here due to the multiple replies already posted.
However, we have deleted the duplicate posts on other forums in order to discourage shotgunning of posts
exmotocrosser
Sep 13, 2019 06:12 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
slowgsxr97
Sep 8, 2015 07:33 PM
