Razr's
Old Sep 20, 2000 | 05:11 PM
QuadTeun's Avatar
What do you guys think about Maxxis Razr's?
Is this a good tire or should I go with Shredders, Turf Tamers or something like that?
Old Sep 20, 2000 | 05:44 PM
hot_shoe_cv's Avatar
It would help if you gave a little info as to your riding style, type of terrain, brand of machine, etc., so someone could give you a qualified reply.
Old Sep 21, 2000 | 11:48 AM
QuadTeun's Avatar
Ok, forgot that one..
Well, I've got a Suzuki Quadrunner230, I usually ride on grass,gravel, hard sand and sometimes mudd. I ride kind of agressively(like to slide through corners, do 180 degree turns etc.)
Hope this helps.
Old Sep 21, 2000 | 04:19 PM
Yes, that helps,
It appears that you ride basically on softer terrain(compared to Az)The Razr, although using a softer rubber compound, would probably have decent wear characteristics where you ride. It does hook up well and seems to have good stability in corners according to people I've talked to that run them. They also weigh less than some other brands of tires, I believe. I run Bandits which hook up really well in the hard pack we have here, & yet wear like iron, but you might be better served with a less agressive tread design & lighter weight tire.Just keep your tire pressure up (I run six lbs PSI) to reduce roll-over & sidewall flex in the turns.
Old Sep 22, 2000 | 05:29 PM
hondatrx300ex's Avatar
SHREDDERS!!!!!! they are really good.....last a long time too if you saty off the road........later
Old Sep 23, 2000 | 07:14 AM
QuadTeun's Avatar
I thought Razr's were almost the same as Shredders?(they've got the same X-patern, don't they?)
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
bermbanger
May 5, 2001 12:53 PM
