Purpose of a lift kit
#22
frankd,
You put a lift ki on it then. The only difference between mine and yours is that I put the spacers between the shock and the A-arm.
Can you explain how you got the springs off the shocks and what you used to as spacers?
I was test fitting the lift kit on my 500 and I found out that only way to lift it was to compress the shocks because the A-arm don't alow you to go any farther down. This is because the shocks are so soft.
#23
on the top of the spring is a washer with a slot cut in it compress the spring and slide the washer out,the rear springs are easier and can be done by hand,the fronts are stiffer and can be taken apart by hand but i had to use a log splitter to compress the spring to put it together(it was all i had to do the job).when you take the spring off there is a plastic spacer,flat washer,and an aluminum washer i used pipe that i had around for spacers put the pipe between the aluminum washer and flat washer.i did 2 quads in about an hour.
#26
I can see it now--www.frankdliftkits.com
with a * by Artic Cat--at the bottom of the page it says "not yet available for Boner's AC", please use the link to www.Boner'sACliftkits.com.
Wonder if he can make a Max6x6 lift kit??
#28
Does anybody have any pictures that you can send me of these home-made lift kits? My email is vpoe@alltel.net Do you think it is possible to lift my Bayou 220?
#29
i dont have any pics,but i will take some because im going to redue the rear shocks,with weight on it the rear squats a little more than the front so im going to go with 1 or 1 1/4 in. spacers.im from n.e. pennsylvania.before my arctic-cat i had a 95 honda 300 4x4 and i did the same thing to it
#30
Hey frankd I like the idea of your lift kit can you send some digital pics this sounds like a h#ll of a good idea. where you located and what kind of territory do you ride...PS my email is available on this message.
Artic Cat 500 auto...Might be lifting my CAT
