Mudlite Tire Pressure
Old Mar 15, 2005 | 09:48 PM
slowneasy's Avatar
Default Mudlite Tire Pressure
hey guys could use alittle help just put a set of mudlites on my boys twolf and am wondering what pressure i should put in them, cant find no info on tires, most riding is done on woods roads and trails, also want to put a set on my bruin would pressure be the same. thanks for the help
Old Mar 15, 2005 | 11:56 PM
elkbow's Avatar
The max PSI should be listed on them at 7 psi. I run mine at 5.5 psi. I've seen others running as low as 3 psi for mud....I would stick in the 5 to 6 psi range.
dave
Old Mar 16, 2005 | 09:23 AM
slowneasy's Avatar
thanks dave i will try that. kris
Old Mar 16, 2005 | 06:17 PM
Chilly's Avatar
What does the ATV manufacturer recommend? I run mine at 3.5 pounds, which is what Honda calls for in the Foreman.
Old Mar 16, 2005 | 07:55 PM
craggy's Avatar
We run 3 psi when rock crawlin and 4 psi when we are just trail riding.
Old Mar 17, 2005 | 02:18 PM
slowneasy's Avatar
thanks guys my owners manual says 3.6 is normal but that would be for the stock tires most likely the same for the mudlites.
Old Mar 17, 2005 | 07:22 PM
silverbullet2005's Avatar
I put mine at 7psi. when I got them from the ups guy they were all different but had between 12 and 20 psi.
Old Mar 31, 2005 | 11:55 PM
400PrarieXLT's Avatar
Mine came from UPS with about 20 PSI in them, must have been from mounting. I run right at 5psi all the time, and find it to be a good all around pressure. I have had one rear tire leak down to nothing and other than being a little lower and wider, it still rode fine! I now check them before every ride.
Old Apr 1, 2005 | 05:49 PM
jayri's Avatar
I run them on my explorer and run 5 in the front and 4 in the rear. Little more in the front to steer easier and little less in the rear for traction.
Old Apr 1, 2005 | 11:36 PM
PolarisTheOnlyWayOut's Avatar
I ride mine on 10 psi...gives me more floatation in tha water lol but also put dow to 7 from time to time...
