Saranwrap and zip ties for torn CV boot??
Old Apr 3, 2005 | 11:14 PM
WyoBullRydr's Avatar
Default Saranwrap and zip ties for torn CV boot??
outboard right rear CV boot is torn, think it would work to take 10/12 wraps with the saranwrap and a couple zip ties to secure it for a days riding without destroying the CV joint??
Old Apr 4, 2005 | 01:19 AM
BIGCHEVROLET's Avatar
its not worth to blow out a hundred dollar joint just to go ride for a day.....get a boot kit tommorow and put it in....unless you wanna risk destroying the joint and dropping quite a few extra bucks down on something that could be easily avoided
Old Apr 4, 2005 | 02:15 AM
Here's the problem with that. I won't have the money for the kit until the end of the month. And, I got so far as the remove the wheel and looked at my grizz and the big @$$ nut holding the hub on the shaft is crimped into the shaft. I tried, and can't get it off. So, I will be forced to pay the dealer the $125.00 to do it. My manual says there is supposed to be a carter pin in there, it's not there, they crimped it at the factory.
Old May 12, 2005 | 12:08 AM
katman's Avatar
i had a hell of time getting that off as well ,a huge breaker bar
and anti seeze after that.
Old May 12, 2005 | 05:36 PM
THECVMAN's Avatar
You might try stopping by a tire shop or garage and see if you can slip them a few buck or brews to hit it with the air impact wrench. It would be a lot cheaper that $125 bucks to loosen a nut! If you need any pointers PM me.
Old May 12, 2005 | 07:28 PM
katman's Avatar
yea,,,he did use a impact gun on the back, that oll farmer
got every tool made .......dresses like he aint got a pot ta
**** in ........but he can wrench,,,,,,and i learn more about my bike
with each break ......,[knock on wood,i havent had many.}
[img]i/expressions/face-icon-small-wink.gif[/img]
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
