Driveshaft vs Chain ?
Old Nov 4, 2005 | 06:31 PM
Bozzy's Avatar
Default Driveshaft vs Chain ?
Hi guys I was checking a new bike (2wd) and notice it did not have a chain but a driveshaft is this better what would be the purpose ?......more torque ? or towing capacity ?........dunno....most I see in 2wd have a chain.....I know the 4wd are shafts....sorry I'm kinda new......so just learning here.....thanks for input !
Old Nov 4, 2005 | 07:30 PM
Scooter86's Avatar
Knows Old ATV Questions!
Shaft drive is fairly maintenance free, but robs a bit more power than chain drive. Chain requires routine maintenance, but gives more gearing options. Riding with a loose chain can leave you stranded, and in a worse case scenario leave you with a broken engine case as well.
Old Nov 4, 2005 | 08:48 PM
Bozzy's Avatar
Are shaft-drives popular or prefer over chain and are these found on more expensive atv's ?........sounds like a better drive system....also have they been out a while ?.....thanks again !!
Old Nov 4, 2005 | 11:03 PM
maddog56's Avatar
Basically chain drive is better for sport quads because you lose less hp and it weighs less, also its possible and easy to change gear ratios.
Shaft drive is used for utility machines where rugged equipment is more important than the small percentage of hp lost to the much more reliable shaft drive.
Old Nov 5, 2005 | 07:23 AM
Scooter86's Avatar
As you can see, each has there place in the ATV world. It is much more common to have a sport quad with a chain drive and a ute with shaft.
Old Nov 5, 2005 | 10:49 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Not many sport bikes have shaft drives. I have it on my 250EX (a bike best suited for adult beginners or intermediate kids), which is based on the Recon utility. A couple of advantages that weren't mentioned are that it gives you some extra ground clearance over a chain drive, and if you are in the mud and water a lot, a chain can take a real beating.
The various disadvantages of shafts have already been mentioned, but the real issue is WEIGHT. A chain and two sprockets weigh a whole lot less than all that stuff it takes to put together a shaft drive! With the standard in performance sport bikes now being 350 pounds, it would be difficult to make a shaft drive that comes in anywhere even close to that. (The V-Force for example comes in at well over 500 pounds, as I recall???)
Old Nov 5, 2005 | 11:30 AM
enFORCER's Avatar
Originally posted by: reconranger
Not many sport bikes have shaft drives. (The V-Force for example comes in at well over 500 pounds, as I recall???)
LOL, yep you are right... The KFX700 is the fattest girl at the dance when it comes to sport quads..... But it doesn't feel that heavy when you are on it.
But I must say I agree with everything I have read in this thread so far......
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
