any smart people out there anywhere??
Old Nov 26, 2000 | 09:58 AM
speedy2's Avatar
who can tell if a rear banshee shock will fit my 96 warriori blew my rear shock and was curious if they were interchangeable(big word)??
thanks
Old Nov 26, 2000 | 06:09 PM
bob's Avatar
bob
i had my warroirs shock on my shee while its was at pep a few years back, as i recall the warroirs shock was about an inch shorter, so id expect a banshees shock to jack up the rear of your warroir quite a bit
Old Nov 26, 2000 | 07:34 PM
speedy2's Avatar
hey bob what you are saying is that a banshee shock will fit my warrior? right
BOB you are a life saver man
Old Nov 27, 2000 | 05:20 PM
atv4Stroker's Avatar
If I recall correctly the Banshee shock resivor hits something causing the shock bolts not to match up. Fronts will work though.
Old Nov 27, 2000 | 07:47 PM
speedy2's Avatar
are you dead sure that info is correct?? this is very important
Old Nov 27, 2000 | 08:12 PM
bob's Avatar
bob
id say try it and find out, i went the other way though, and a warroirs shock has a remote res as i recall
Old Nov 27, 2000 | 09:56 PM
speedy2's Avatar
the only problem with find out and try is i 14 and aint got alot of money.
thanks for the help though!!
Old Nov 28, 2000 | 09:42 PM
ms15's Avatar
Hey, I'm assuming you already have a banshee rear shock laying around and you are wandering if it will fit. How will it cost you any money to take the broken shock off and try the banshee shock? I took my cousins shock off of a KX100 dirtbike and put on another off of a KX80, the shocks were the same size, and it wasnt extremely hard to do. Give it a try.
Old Nov 28, 2000 | 09:55 PM
speedy2's Avatar
no i dont have another shock, but i found one to buy cheaper than a warior shock! it would cost me to buy it!!
Old Nov 29, 2000 | 09:31 PM
ms15's Avatar
Go measure it and check out the way it mounts to make sure. It might work. if not then look for a used warrior shock...i'm sure you can find one somewhere.
shimanok2
Jan 29, 2016 07:37 PM
kbazzy
Sep 26, 2015 11:26 AM
Irishman301
Sep 23, 2015 01:47 PM
01ssls1
Sep 22, 2015 06:50 AM
Elkaholic
Sep 6, 2015 02:44 PM
