Mounting Paddles
Old Aug 29, 2006 | 01:03 AM
Raptilla's Avatar
Default Mounting Paddles
Maybe a dumb question but I have heard mixed answers.
I have just picked up and mounted new Skat Trak Extreme paddles and wheels on my Raptor 700r. The paddles were already mounted on the wheels. Upon inspection I noticed that my hubs don’t line up which causes the paddles to be offset from each other. So here is my question. Do the paddles HAVE to line up on both sides of the quad for a straight launch or is it just preference and riding style?
Old Aug 29, 2006 | 10:53 PM
Speeddrive1's Avatar
It's easy to time your tires. Just pull the cotter pin and remove the castle nut on the end of the axle that holds the hub in place. You want to do this with the tire/wheel still mounted to the hub so that when you slide the hub off the axle and turn it till the tires are timed(paddles are lined up from one side to the other). Then retighten the castle nut and replace the cotter pin. The ride will be much better on hardpack.
Old Aug 29, 2006 | 11:17 PM
Raptilla's Avatar
Thank you very much. I already have my hub off and was waiting for a definitive answer. Time to hit the dunes this weekend with paddles instead of my *****. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 29, 2006 | 11:28 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Yup.. what speedrive1 said.. if you dont have them in time they will shake the livin heck outta ya on the hard stuff. well they do anyway but worse
Old Aug 30, 2006 | 03:01 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Sometime if the bead isn't to tight, you can flat the tire and just shimy it on the rim until they line up.
Better yet, when I have the tires mounted, I make sure they line them up from the get go!
Old Sep 1, 2006 | 01:37 AM
Raptilla's Avatar
Thank you all very much, I was able to get them pretty close without taking them in to remount them. Only one more day at work then the DUNES ARE IN TROUBLE!!
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
chewy78
Sep 8, 2015 10:37 AM
toonces
Sep 5, 2015 01:14 PM
