Tire question
I,m in need of some new rubber,dont want something fancy,just a good 4 ply tire with orginal tread type that came on my old 94 quadrunner,Problem is my rear tires size are24x11x10,fronts are22x8x10.Seems to be hard to find those sizes.Iwant to keep orginal rims what size can i go to on those rims assuming i have plenty of clearence?Not real sure what #,s mean on tires,Thanks,Paul
Well if you have 24x11x10
24 = tire height from ground to top of tire
11 = the width of the tire
10 = the diameter of the RIM
So any tire with a 10 as the last number will fit you Rims.
You said your having troubles finding tires with those same numbers if you tell me what kind of rideing you do the most Ill recomend some tires that will fit the bill.
Getting the right tires for the type of trails or rideing you do (mud, snow, sand, dirt roads, gravel) make a HUGE difference on the ride, feal and performance of your quad.
I been rideing most of my life and know where to get some good deals and will do my best to hook you up with what you need
MUDLORD,Thanks for the reply,I mainly use my 4 wheeler to huntwith on my own property,hard packed trails,no getting stuck issues at all,also to drive around pastures and such,no racin,boggin or water to cross,thats why i figgured orginal type tires again.They lasted since 94 and at my age dont think i,ll need any more!lol.i would like 4 ply instead of 2 thou. Thanks,Paul
these are what id suggest Kenda Bear Claws you wont find a better tire for the money !!!
They last for ever and do well in any conditions you mentioned
heres a link
Fronts
http://traxms.com/Merchant2/merchant...Kenda-Bearclaw
Rears
Google this "atv tires free shipping" and find your best deal also check ebay
heres a link
Fronts
Rears
toonces
Oct 16, 2019 12:11 PM
Jul 24, 2015 11:57 AM
