Grizzly Axle Boot
Old Aug 7, 2007 | 01:15 AM
bradgooch's Avatar
Default Grizzly Axle Boot
07 Grizzly 660 - Pressure washed it after some mudding and now one of my axle boots looks like a balloon. I assume that it is full of water from the pressure washer. How do I get it out?
Old Aug 14, 2007 | 01:08 PM
MikeM's Avatar
pull the axle off, break the band, completely clean the joint, repack and replace the band. you do not want any water in there and be sure you do not have a tear or hole. axles are not cheap.
and never use a pressure washer to clean an atv (or motorcycle), it just washes out grease and forces water in everything.
Old Aug 14, 2007 | 01:36 PM
bradgooch's Avatar
Can I purchase the band without purchasing the boot? Can I pick this up at the dealer? Thanks for the help.
Old Aug 16, 2007 | 09:48 AM
MikeM's Avatar
my advice is to call a dealer or check someone's online microfiche. I just bought kits as my Arctic Cat was always suffering from ripped boots. I would think yes, but check with your dealer. I'd go the for large band, you should be able to leave the small band on an roll the boot back over it. If it is the inner joint, you may be able to get at it without removing the axle. Good luck.
Old Aug 16, 2007 | 11:34 PM
bradgooch's Avatar
Thanks for the help. I will stop off at my local dealer tomorrow. Thanks again.
Old Oct 19, 2007 | 04:39 PM
Andy Bassham's Avatar
A dealership or maybe an auto parts store might have a fast-boot kit. Cheaper than the actual manufacturer's part. I replaced 2 on my 660 one time. (one was torn and I had to take both off to do the 1, so I did both). $25 for the new boot kit when I did it ($50 total). I'm sure some auto parts place would have access to be able to get just the clamps.
Old Oct 26, 2007 | 09:57 AM
CraZySteve's Avatar
The Yamaha factory bands are pretty slick - you do not need a tool to install them! I had to buy the KD tool for tightening the CV boot bands as I didn't buy a Yamaha boot kit but a Moose kit. The bonus there is the Moose boot is stronger (rubber) than the Factory Yamaha...
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
jankerstien
Sep 21, 2015 03:09 AM
