Homemade atv/snowmobile
Old Mar 19, 2008 | 09:31 PM
max123's Avatar
Default Homemade atv/snowmobile
Well me and a buddy put a yamaha warrior front and rear suspension in a 96 formula three frame. We put a honda 750 bike engine in it, and its not done yet but heres the question: we need to know what gearing to use? there will be a chain from the engine to the axle (the first axle which is located where the stock sled axle was) Then there will be a chain from the axle to the actual atv axle! Honestly I dont even know what gears to start with! I kind of thought two gears that are the same from engine to first axle but no idea what size. assuming smaller! But any help would be appreciated. Thanks
Old Mar 20, 2008 | 01:59 PM
deanz400's Avatar
you have to figure out your gear ratio you want and start plugging in # until you can figure it out
Old Mar 21, 2008 | 11:55 AM
MikeM's Avatar
I'd start by reviewing what the bike had for sprockets. From there look at the difference between the tire height of the bike vs what you will be using now. You probably aren't going to need the speed the street bike had, so a shorter tire than the bike will get you a lower ratio and closer to what you might need.
I think you can get close using the stock bike sprockets on the engine and your jack shaft, then using the same toothed sprockets on your jackshaft to rear axle if your tires are shorter. Keeping the sprockets the same on the jackshaft to rear axle the same would simplify changing the ratio later. You'd only have to change one sprocket. The engine sprocket is the cheapest to replace.
Of course there is a method to take all the guess work out, but that involves a little bit of math....
Old Mar 21, 2008 | 08:11 PM
max123's Avatar
Thank you very much!!! that will help alot! That oes make sense, and your right Im not looking for extreme speed, just something to toy with! Thanks again!!!
Old May 4, 2008 | 10:09 PM
Scramble96's Avatar
Do you have any pictures of this creation??? This sounds interesting!
Old May 6, 2008 | 10:15 PM
CraZySteve's Avatar
Yea.. Pictures...
Ski-Hon-Maha? or Yama-Doo-onda ? Hon-Doo-Aha?
LOL
Old May 7, 2008 | 11:12 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Sounds like a cool project! [img]i/expressions/face-icon-small-smile.gif[/img] Pics would be great!!
The sprocket gearing math isnt all that tough. Including the wheel dia does get tough. With the sprockets think of it like this...say you got a 15 tooth on the front and a 45 on the rear.(between the engine and the jackshaft) 45 divided by 15 is 3. That gets you a 3 to 1 ratio. If you do the same thing between the jackshaft and the rear wheel you get another 3 to 1 ratio. But you now need to add them up. You have actually got a 6 to 1 ratio from the engine to the rear wheel..
cSchwartz
Jul 12, 2015 07:42 PM
roosthrower
Jul 29, 2003 01:56 AM
BigBadScrambler
Jan 17, 2003 01:21 AM
speed11x
Oct 18, 2002 04:35 PM
Mitch Cyr
Sep 26, 2002 11:09 PM
