Tire foam??
Old Mar 29, 2008 | 06:19 PM
ozarkeun's Avatar
Default Tire foam??
do they make a tire foam to put in your tires to keep them from going flat? i know they do for skid loaders i'm not talking about slime but foam that fills your whole tire solid
Old Mar 29, 2008 | 08:52 PM
ctateusa1's Avatar
Default Tire foam??
You can buy fix a flat(but you really want to buy new rims anytime you buy new tires?)
But I have never seen a tire foam that would make your tire solid. Besides that would ride like a "skid loader" at 50 mph. you really want that?
Old Mar 30, 2008 | 12:13 AM
shea_davis1214's Avatar
Default Tire foam??
yeah, it would prolly feel like riding over a washboard and prolly bounch you of you quad or you'll have a really sore a$$. lol. but the good thing about it would be that you'll never have to fix a flat tire........................shea.................. ....
Old Mar 30, 2008 | 09:22 PM
jrafter's Avatar
Default Tire foam??
theres www.tireballs.com
Old Apr 7, 2008 | 10:22 AM
GunnSmoke's Avatar
Default Tire foam??
wouldent that tire foam add alot of weight to the tires?? a skidder and farm tractor would probably benifit from the added weight but there also geared for it. and as shea said it would make for a rough ride.
Old Apr 7, 2008 | 03:14 PM
sjbr549's Avatar
Default Tire foam??
the foam would'nt add that much weight it's mostly air.the fluid they put in the tires add alot of weight.i know some "drunks" they roll their quads all the time so they had the fluid put in them. a 24x11x10 tire and rim wieghts about 100lbs with fluid in it .
Old Apr 14, 2008 | 10:36 AM
MaineWheeler's Avatar
Default Tire foam??
Usually they put calcium in tractor tires and I wouldn't think you'd like the ride you would end up with at all - No matter the supposed advantages, at least in a atv. IMO
Old May 10, 2008 | 11:34 AM
DCMAC214's Avatar
Default Tire foam??
"Slime" is one product that plugs holes from the inside. Available just about anyplace that sells automotive stuff, including WalMart. We've got a dealer in the area that will slime all your tires free, whether you bought them or the machine there or not. "RideOn" is another brand, think used mostly in motorcycles. There are others. Just be sure to tell your mechanic that you've got something in the tires - it can be VERY messy when you break the bead. If I was the wrench and wasn't told I'd be really POed. Most places will charge extra to change a tire with a sealant. Better to break it yourself and wash it out (only water, no solvents or soap needed).
Ride Happy - Ride Safe
DC
Old May 10, 2008 | 11:57 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Tire foam??
I run fix-a-flat in all my tires all the time from the day they are new! It will seal any thorn holes...you will never even know you got them. That and a plug kit with CO2 cartridges is all I have ever needed!!!
My experiences with Slime has been very negative!!! It just dries up and leaves a nasty completely useless crust inside the tire......
Tire ***** cost a small fortune, as I recall.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
mbriggs
Sep 13, 2015 10:47 AM
Steeldon
Sep 9, 2015 09:38 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
