Swamp lites or kenda bear claws???
Old Jul 12, 2008 | 12:29 AM
  #21
MaineWheeler's Avatar
Default Swamp lites or kenda bear claws???
The only drawback that I now have found is that in sand if you get throttle happy they will dig trenches other then that aces--for the money and performance they give me in all the other areas I'd still buy them again
Old Nov 27, 2014 | 12:04 PM
  #22
kdwellssr's Avatar
Any body got pictures? I have a 500HO am going to put swamp lites on it from stock on it now. I just want to know if I should go to the 26" or stay with 25". Do the 25s make it look bad to the bone and do the 26" cause issues that require extra upgrades?
Old Nov 28, 2014 | 09:12 AM
  #23
TLC's Avatar
TLC
My first 350 Grizzly had 26x9-12 front 6ply Maxxis Zilla and 26x11-12 with the aggressive 1.19" lug and handled them no problem without any noticeable power loss so your 500H.O better.
No up grade was needed just a tire change and go, of course Zillas are the lightest 6ply mud tires made.
compare for yourself on this site
ATV Mud Tires : Best ATV Tires
Narrower Swamp lite 26x10-12 with a shorter 1.12 lug is 27lbs Interco Swamp Lite
The wider Zilla 26x11-12 with a taller 1.19 lug weight 23.3lbs Maxxis Zilla
Even the much larger and wider Zilla 28x12-12 weigh only 27.5lbs if you scroll down the above link.
Larger tires do not cause power loss it's heavier weight that does so just keep a eye on that when choosing tires.
Old Nov 28, 2014 | 05:47 PM
  #24
user493's Avatar
Moto Psycho
Some years the stock tires on a Sportsman 500 were 26" so there's no problem going from 25" to 26" as long as they aren't too wide.
Old Nov 28, 2014 | 06:38 PM
  #25
kdwellssr's Avatar
My plan is to go 1" wider.... that's going to 9 in front and 11 in back. Not looking for any clutch problems at this time.
Old Jan 12, 2015 | 06:14 PM
  #26
Quadrider4's Avatar
Originally Posted by mudslinger0787
How well do sl's wear a lot of people are posting that they wear very fast..
Extremely if used on pavement, I purchased a pair for my 500 scrammy and month later the fronts were almost worn right off.
Keep in mind tho I did a lot of pavement riding probly once a night at least.. Other then that great tire! Just don't use on the pavement if u want durability..
Hope this helps
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Sep 10, 2015 01:56 AM
1000gade
Sep 9, 2015 03:35 PM
