how to adjust rear shock on 86 honda 250r?
Old Jul 12, 2008 | 11:34 PM
86honda250r's Avatar
Default how to adjust rear shock on 86 honda 250r?
i think the rear shock is bottom out. is there a way to adjust nitrogen on the shock?
Old Aug 2, 2008 | 09:19 AM
Honda777's Avatar
Default how to adjust rear shock on 86 honda 250r?"></title><script src=
I recomend you don't try messing with the nitrogen , with the year of your bike I hate to say but your shock may be shot , however all is not lost I belive that model is adjustable and to do so there should be two lock nuts on the bottom of the shock loosen the bottom one and tighten the top one , only go about an inch at a time then test ride if you get it to tight it may throw you over the bars at the worst possable time ,also if you go to honda of troy web sight and look up that shock there will be an exploded veiw that may help show you what I mean. I hope this helps you out bro.
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
MNatv89
Jul 7, 2015 11:36 AM
Rider252
Jul 6, 2015 03:37 PM
Jkfx400P
Jul 6, 2015 10:04 AM
