help with tire problem
Old Mar 23, 2009 | 10:18 PM
whipred's Avatar
Default help with tire problem
I have these tires ams swamp fox tires on motosport alloy rims they go flat over night the tires say they need bead lock rims but I dont really see any bead rims for a can-am outlander. At least not like what the goodyear man showed me are this tires no good for what I need or do I just not the right rims.
Old Mar 24, 2009 | 08:06 PM
tallman01's Avatar
i would break them back down and apply a good coating of bead sealer, should cure your problem if thats were they are leaking from
Old Mar 25, 2009 | 08:11 AM
TLC's Avatar
TLC
It thought all ATV rims where the same, a tire company that sells replacement tire that requires special rims would be out of business in a hurry. All rims leak aire slowly I find, you could try a can of "Fix a Flat" / Slime to help seal the bead or put tubes in the tires like I did.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
