Will these tires fit my rim CORRECTLY?
I have a 650 Rincon with stock tires 25-8-12 and 25-10-12. I am looking to put Bighorns on and want to go a little taller and wider. 26-9-12 and 26-11-12. Will they fit my rim correctly as far as width goes. Not worried about clearance, just if they will fit my rims?
Thanks
Thanks
Thanks
Thanks
1st #: 25 -- tires height (not always true height -- but close)
2nd #: 8,9,10,11 and 12 -- tire width
3rd #: Rim Diameter
As far as Bighorns go, they run larger to actually height, the 25" Bighorns run almost 26" once installed.
And wether or not tires fit on your stock rims depends on the width of your stock rims. if it is an 8 inch wide rim a 12'' wide tire should fit good, but if it is a 7 inch wide rim a 12 might bubble over too much, you might want to look into a beadlock rim, or beadlocking the stocks, if possible.
Ok I dont want to steal the forum but could someone send me a message or post how to decide if a certain tire will fit you wheel or not... It kind of confuses me and I just got my 1st 4 wheeler so I am wanting to learn all this stuff... If anyone could help I would appriciate it...
Elkaholic
Sep 6, 2015 02:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
Jul 24, 2015 11:57 AM
