Big Bear wheels on Honda Rancher?
Old Sep 10, 2012 | 08:07 AM
bassadict69's Avatar
Default Big Bear wheels on Honda Rancher?
I will soon be losing my Big Bear 350 due to divorce and have already acquired a Honda Rancher ES 350. Does anyone know if the wheels off the Yamaha will fit the Honda?
The wheels on the Bear are stock but have better tires than the Honda which has stock tires so I am wanting to keep my better tires if possible.
I will check tire sizes later to see if the better tires will fit the honda wheels, I know they are a bit larger than the stock were but not sure on the size. It would sure be nice to simply swap the whole wheels/tires!
Old Sep 25, 2012 | 04:35 PM
Y2daT's Avatar
Possible but I doubt they will work. most Honda use a 110 pattern and most Yamaha use a 115 pattern. best bet is to check the last number on the tires like (25x10-12) the 12 is the rim size. if both sets end with the same number then they will be swapable.
Your probably looking at about $40.00+ bucks to have both sets switched over.... if they are big mud tires it may cost more
the Honda 350's preform well with up to a 26" tall tire any larger will bog it down a bit...
Old Sep 25, 2012 | 07:27 PM
95wolv's Avatar
The Yamaha utes all use the 110 pattern, the 115 was the rear on some of the sport quads. I put my 23" Wolverine tires/wheels on my sons 250 Recon, they fit perfect, and looked great. Lots of guys get the Rubicon or Rancher aluminum wheels and put them on their Yammy utes, it will fit just fine !!
Old Sep 26, 2012 | 05:33 AM
they fit but the rear tire rubs the muffler. Looking into spacers now
Old Sep 26, 2012 | 06:55 AM
TLC's Avatar
TLC
Should work this chart has them both using 4/110 bolt pattern. ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
Old Sep 26, 2012 | 08:47 AM
95wolv's Avatar
oooo......I just happen to have a couple of 1" spacers that would fit you just fine !!
Old Sep 26, 2012 | 01:43 PM
How much?
Old Sep 26, 2012 | 02:40 PM
95wolv's Avatar
how does 30 bucks plus shipping sound? pm me your zip and i can check shipping
Ean
Dec 19, 2022 08:48 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
