First atv, what size tires?
1" more width should have better traction on hard stuff and better flotation in soft stuff. More area = less ground pressure. They'll fit the same rim but will each tire will stick out 1/2" making your overall width 1" more, and they'll stick in 1/2" closer to the frame. Neither should be a problem but look between your tires and whatever is next to them to make sure. But a 22" tire will have 1/2" less ground clearance than a 23". Dirt Devils come in 23x10x10 too, so they'd be the same width and height as the Bear Claws.
https://www.gbcmotorsports.com/products/dirt-devil
matthewvi
10-28-2006 05:37 PM
gogrizz
02-24-2006 07:11 PM
