Rim Size ??'s
Dirt-
Hey, I'm running 27x9.75x12 Bi Claws up front, with 27x12x12 Tri Claws on the rear of my 'Cat, on the STOCK AC rims. They are a 12x6.5 rim. With tires, the manufacturers always post heigth, then width, then rim diameter-always in that sequence, but with rims, I honestly don't know which way they measure it. In your case, I am assuming your tire would actually be a 20x8x10-thinking that your 20" tall tires measure 8" wide, on 10" rims, is that correct? Or, am I wrong, that they really do measure 10" wide, on 8" rims? I'm used to larger stuff, so it kind of seems funny to me to have a tire width actually wider than the wheel rim diameter-like I said though, I could be wrong there. So, with that in mind, I hate to say it, but I don't honestly know if you need a 8"x10" rim, or a 10"x8" rim??? Ordering the wrong one would really be a hassle!
Somebody must know the true dimensions or wheel guide measurements???
Good luck,
Mike
Good luck,
Mike
Yeah, this stuff is confusing. I've never had to buy tires and rims before. Everywhere I look the size of tire 20x10x8 means 20 tall 10 wide and 8 wheel dia. but the rims ie. 8x9 is 8 dia. 9 wide. I don't know if I should get the 8x8 or match up the tire with 8x10 rims. I know there has to be someone who knows what I'm talking about and has the answer.
I'll restate the question in a simpler form: with 20x10x8 tires, what size rims should I get?
Howdy,
If I were you I would stay with 8X8 that is wat comes on a Blaster factory. My Racer came factory with 10X8's on it, and I have 10X8 Douglas blue lables with 22X11X10 Holeshot XCTs mounted on them and they fit perfect.
Danno
Danno
Hey,
I forgot to say that I have a freind with fasttrekers on a 250X they are 20X10X9s, and he loves them. Infact I've been thinking about buying a set of 20X10X10s just to play around with on my Racer. They look great, and my buddy says that they hook-up well and slide good on a stock 87 250X. They should be a blast for a built Quadracer, they should break loose at will and slide on command. My Holeshots are a bit grabby in a slide. Anyway you should like the trekkers alot on a blaster.
Danno
Danno
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
