banshee HELP
Old Nov 9, 2002 | 06:34 PM
2002bansheeman350's Avatar
Default banshee HELP
i have a 03 banshee,i just got it in august and dont have much money to spend on it. As i was out riding I noticed a snapping coming from the chain, i figered that it might becouse the chain was to tight. when i was done i started to play around with it and noticed that i could push my sprocket back and forth. SOmone must of had this problem if anyone has any info on this please let me know.
Old Nov 9, 2002 | 08:50 PM
FMF's Avatar
FMF
You have to tighten up your axle nuts
Old Nov 9, 2002 | 11:08 PM
oh, couse my dad started to talk all this junk about how i striped my axle and every thing. thanx tho ill do that tommorow. the axle nuts are rite next to the sprocket rite
Old Nov 10, 2002 | 12:33 AM
FMF's Avatar
FMF
Yes they are rite next to the Sprocket.
Old Nov 10, 2002 | 10:53 AM
WyoDuner's Avatar
Unless you happen to have a really big wrench you will probablyhave to use a pipe wrench to tighten them down. The torque spec is very high on them - I forget but it's around 140 ft/lbs. If your Banshee is fairly new you should check all the bolts, especially the ones on the rear spindles.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
