Tire Grooving
Old Apr 21, 2000 | 09:48 AM
retro's Avatar
Does anybody have any tire grooving secrets? Are there any inexpensive tools that work as well as a real tire groover? I want to groove my own turf tamers.
Old Apr 23, 2000 | 09:08 AM
Raychalp's Avatar
You don't need to buy a special electric tire grooving tool to cut your Turf Tamers! The tool that I use to do it was less than $10 which is what you pay extra per tire when you buy them grooved from Nac's or anywhere else that does it. It is just called a "nipper" from Channel Lock. It is a special pliers with about a 1" cutting surface. It is perfect for removing ***** on Turf Tamers. It does take awhile and some elbow grease but it is better than wasting money.
Old Apr 23, 2000 | 10:48 PM
mongoose's Avatar
but make sure you use some white chalk or something like that to premark, otherwise you will waste a hundred dollars in tires.
Old Apr 24, 2000 | 03:22 PM
rhino99's Avatar
I think you could use a dremel tool and just grind them off with a bit or something. Heck you could probably even get a sanding bit for a drill and use that.
Old Apr 25, 2000 | 10:39 PM
GriffsFSR's Avatar
I have found what I would consider the perfect tool. It is cheap and easy to use. A guy used a old fashioned calf dehorner when he grooved my turf tamers. It was very easy.
Griff's FSR
Old Apr 30, 2000 | 02:17 AM
Blaster668's Avatar
I also use the Channelock front cut wire cutters. It takes a while but works awesome.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
WilliamBos
Sep 6, 2015 10:53 AM
