RIM SIZE
hi, there is pros and cons, but for your situation i would go with the 10" wheels because you will have less tire flex. People use 8" because they are less capable of getting damaged but i dont see why sand will damage rims so your safe.
Tires mounted on 8-inch rims tend to be more tall and round. This increases forward traction, but makes it harder to slide. They also ride a little softer due to the larger side wall.
I think 10-inch rims look better.
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
