Dunes and Dune Machines Discussion on dunes and dune machines.
What is the best setup for dunes.
Old Nov 9, 2003 | 09:01 PM
derekb21's Avatar
Default What is the best setup for dunes.
Well what is it?
Old Nov 9, 2003 | 11:32 PM
wildchild660R's Avatar
you gotta be more specific, theres endless amounts of money you can put in a dune quad
Old Nov 10, 2003 | 09:24 AM
derekb21's Avatar
Well scince i have a yfz what would be good
susp. setup
along with engine mods I HAVE $1000 TO SPEND
Old Nov 10, 2003 | 09:25 AM
derekb21's Avatar
and i run mostly
woods/harescrambles
plus a couple of trips to the dunes
and racing my buddys around the mx track
Old Nov 10, 2003 | 12:20 PM
green700's Avatar
We've got 23" 10 blade extremes on our yfz. Two days ago my uncle raced it against a built raptor at sand mountain ($2700 into engine he said). Both races it was a dead even tie. And the YFZ doesn't have a pipe yet. Just removed lid/peashooter.
Old Nov 10, 2003 | 12:39 PM
2Gordons's Avatar
paddles, and smooths in the front
Old Nov 10, 2003 | 01:49 PM
You should just soften up your stock suspension and get a pipe, take the lid off, do that cam mod, paddles, re-jet, maybe different gearing, and maybe bump up your compression. Talk to selector I think hes got quite a bit of stuff done to his.
Old Nov 10, 2003 | 11:05 PM
WyoDuner's Avatar
Longer, wider, extreme haulers, front sand tires, more HP.
Old Nov 11, 2003 | 12:36 AM
buddah's Avatar
Just what Wyoduner said. I have a full HMF pipe, K&N filter set up, cam mod, jetted, and it runs strong. I have a 12 tooth front sprocket when I run paddles, and that's not very often. I put a set of wheel spacers on the rear for more stability and cornering speed. I weigh 210 lbs. and run my suspension on the stiff side for jumping. I would like to get a set of Houser long travel a-arms someday. I had them on my Dale and they performed great.
Old Nov 11, 2003 | 02:51 AM
Trx440's Avatar
3 gallons of Absolut, 2 gallons of real lemonade, 1 gallon of cranberry, 2 cases of Corona and a bologna sandwich. I'm good for a week. Oh yeah, quad, fuel, and baby wipes.
