Super Buffs
From what I understand the tripple buffs are measured circumference rather than diameter??? I guess there can be a lot of variation?
Someone must know more than me on this.
Are you running a turbo?
I'ld say an 8 paddle would be fine. Give you a little more wheel spin.
The taller the tire is in back the less castor you have which makes the quad less stable at high speeds (unless you adjust your A-arms.) I'ld think 22's should be fine too.
