Dunes and Dune Machines Discussion on dunes and dune machines.
skat-trak extremes
Old Jan 29, 2005 | 10:02 PM
DSengineer's Avatar
Has been here a long time!
Default skat-trak extremes
Yes Skat-Trak did change their carcases last year and yes they are heavier. Standard haulers and extreme haulers all use the same carcases the only difference is the paddle material uses. I was commenting on the weight difference between standards and extremes, not last years carcases and this years. As far as their carcases go you don't have a choice any more so its really a mute point. You get the heavier ones unfortunately weather your buying standards or extremes.
Old Feb 2, 2005 | 11:35 AM
CTracingraptor's Avatar
i had 20x10x10 10 paddles extremes for about 2 years, and they grip way too much for me, and i help burning up clutches.
i swapped to a 22x11x8 7 paddle, and they are significantly faster than the extremes, i need to be able to get my tires spinning for races, and the extremes bit too much.
they are not a bad tire, but i highly recommend a 7 paddle for ANY raptor,
RapFam runs 8 paddles, and he can pick up more top and and speed by switching to 7 paddles
craycraft 730, 7 paddles
craycraft 686 7 paddles
LCC 686 7 paddles
sparks 690 7 paddles
sparks 690 8 paddles.
do you see the trend.
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
