Dunes and Dune Machines Discussion on dunes and dune machines.
raptor gearing
Old Jan 30, 2005 | 10:40 PM
BigDylan's Avatar
Default raptor gearing
i want to re gear my raptor for the sand
what do you guys suggest i would say it could handle some more top end but not too much
i dont want too much of a drastic change
Old Jan 31, 2005 | 12:34 AM
maddog56's Avatar
A lot of it depends on whether you will run paddle tires or not, and if so what kind, size, and # of paddles. Typically you drop a tooth in the front (or the rear equivilent) when switching to paddles for extra low end to turn them.
Old Jan 31, 2005 | 07:08 PM
BigDylan's Avatar
i have douglas wheels blue front black rear
itp sandastars all the way around
20x11x10 r
21x7x10 f
i was wanting more top end like maybe 1 tooth bigger in the front but i dont know
Old Jan 31, 2005 | 07:41 PM
duneittilludie's Avatar
Without heavy modifications and the increased horsepower that comes with it i dont think you would be too happy with 1 extra tooth on your front sprocket.Decreasing the size of your front from the stock size of 13 to a 12 would probably be a better choice for you.
Old Jan 31, 2005 | 11:08 PM
BigDylan's Avatar
thanks guys i have decided that i will buy a stock size rear and a stock size front along with 1tooth bigger and one tooth smaller for the front and well see what that does
i just hope i dont throw the chain seeing as how the casesaver mount is broke
Old Feb 3, 2005 | 01:03 AM
mstrquad's Avatar
mine are gone too
i drop 1 in the fr and came out of the hole like gang buster only lost a bout 3 mph on the top end
Old Feb 8, 2005 | 01:07 AM
CTracingraptor's Avatar
Word to the wise
1 tooth in the front is the same as 3 in the back
i run 12/44 on 21/11/8 haulers,
you run 20 inch tires on that 12 tooth and youll loose a lot mroe than 3 mph top end.
Old Feb 8, 2005 | 12:51 PM
344PV's Avatar
Originally posted by: CTracingraptor
Word to the wise
what gear you pulling on olds with an 12/44 3rd or
4th???
Old Feb 11, 2005 | 08:38 AM
Rockinfigs's Avatar
Hey CT..im currently runnin 12 tooth in front with 20 inch ITP sand stars in rear and 21 in front...now do u recommend me going up to 22 inch rears? i just ride dunes and race comp hills..thks
Old Feb 11, 2005 | 09:36 AM
344pv, i weigh 260lbs and my raptor will scream to the top of hill in 3rd, i can go up in 4th just not as fast. i put my 140lb girlfriend on my bike and she can run up hold in 4th screaming to the top. RAPFam says im still alittle low on my gers, he wants me to go back to the 13 front, but i think im going to leave i love it.
Rockingfigs, if all you are is a raceer, then why did you by Sand stars in the firs place, but yeah i highly recomment the 22 tires i love them, i had a set of 20's haulers, and swapped them out to the 22s did my sprocket change and i gained so much top it, its perfect.
22's will not clear the stock swingarm though, you have to remove your stock heel guards or atleast bend them out of the way, they will bend back and start eating away at your tires, i know this from experience.
hope that helps, PM if you need any direct answers
