Dunes and Dune Machines Discussion on dunes and dune machines.
KERMIT CHATTER
Old Mar 8, 2006 | 07:45 PM
  #1261
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Default KERMIT CHATTER
Originally posted by: DuneDragin
My favorite vibe is disguised as a LT250...not very compact...but a powerful tool.
No batteries required.
To bad spring break plans are off to go riding!
Anybody going to the sandhills or to KSI riding for Spring Break?
So you just sit on the gas cap and go vroom vroom? I hear the thumpers are better for that purpose.. First time i met a guy i ride withs wife i said sompin like that cuz he put a new exhaust on her ATV. well that went over like a wet fart at a protology exam [img]i/expressions/face-icon-small-sad.gif[/img]
  #1262
DuneDragin's Avatar
Dune Rider
Which one of you is Pink?
The Oster will make your teeth chatter! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 8, 2006 | 07:48 PM
  #1263
Just4Kicks's Avatar
But sometimes this ONE is needed first.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 8, 2006 | 07:49 PM
  #1264
Monkey Rider
Afro-Engineer
Why stop there i have a Vibratory Consolidating tool for pouring concrete walls in the shop. I aint conviced a girl to try it yet but that baby will make your teeth chatter standing on the forms.. Then there is the HOpak and thats an attachment ofr the big exavator [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 8, 2006 | 07:51 PM
  #1265
DuneDragin's Avatar
Dune Rider
LOL at J4K!!! you have a point for sure!
Old Mar 8, 2006 | 07:52 PM
  #1266
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Originally posted by: OneFlyCowboy
Originally posted by: Raptorlegs
[i]Originally posted by: OneFlyCowboy[/yeah but if you used one of them Doc Johnsons before you wouldnt want any others. They are bar none the best compact tool you can buy. Ive givin them to several girls [img]i/expressions/face-icon-small-smile.gif[/img] Ive been known to break em out when i performing some tasks [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Bet he tells them it's 8" instead of 4", too.
Hell I'm surprised nobody has lost one! [img]i/expressions/face-icon-small-shocked.gif[/img]
Umm samson those are for exterior use. not a penitrating tool [img]i/expressions/face-icon-small-wink.gif[/img]
Where the hell is the fun in that? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 8, 2006 | 07:55 PM
  #1267
Monkey Rider
Afro-Engineer
5.5HP of vibratory pleasure
Old Mar 8, 2006 | 08:00 PM
  #1268
DuneDragin's Avatar
Dune Rider
Sounds like a good way to chip a gals teeth!![img]i/expressions/face-icon-small-happy.gif[/img]
I know...I just opened up Pandoras box with this comment! [img]i/expressions/face-icon-small-disgusted.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 8, 2006 | 08:02 PM
  #1269
Monkey Rider
Afro-Engineer
Epoxy coated rebar presents a particularly troublesome problem. Steel heads act like an electric hammer, striking any rebar or forms they contact, over 10,000 times per minute, with a force from hundreds to over 2,000 pounds per blow. Contact with a steel vibrator head of as little as one second can chip enough coating to subject the steel to deep rust. Oztec's patented High Efficiency RubberHead vibrator head not only meets DOT non-metal head specifications for protecting coated rebar and expensive forms, but exhibit some very special and unique properties. The High Efficiency RubberHead urethane dimpled construction sends strong shock waves off the entire length of the head, with a larger radius of action, producing denser concrete with less voids to patch.
Why the Oztec RubberHead outperforms any other type of Vibrator.
(a.) When a smooth vibrator head (round, square or any other shape) is lowered into a relatively stiff concrete batch, the front or nose of the vibrator drills a hole. It pushes away concrete faster than it can return. Result, shock waves produced mostly from the vibrator's front end.
(b.) Oztec's patented RubberHead has a large number of openings which allow wet concrete to cool the inner shell. These openings act like suction cups, which keeps concrete in contact with the entire length of the vibrator head, sending strong shock waves into the mass.
  #1270
Just4Kicks's Avatar
I've seen Pandoras box. It's a bit overrated and in need of maintenance.[img]i/expressions/face-icon-small-happy.gif[/img]
