Dunes and Dune Machines Discussion on dunes and dune machines.
Ds650's in dunes
Old Jan 14, 2001 | 01:26 PM
300exSTER's Avatar
Anyone see any really fast ds650s in the sand or on the drag strips? If so what were there setups?
Old Jan 16, 2001 | 02:05 PM
Zorro's Avatar
As long as we're not talking turbo/NOS/alchool (don't know if it works on a 4 stroke), the recipe is always the same. more flow. K&N (with outerwear), big carb (since you don't want low end anymore) or 2 smaller carbs, good spark plug (NGK, Splitfire, NippoDenso, Champion), High compression piston, MORE AGRESSIVE camshaft(s) (<-really important...the first thing to do), bigger valves (especially intake), and freely flowing exhaust. If you have some engineer talent (rather knowledge) you can design you pipe and airbox in such a way that the shockwave acts like a turbo, increasing you pressure at the right moment up to 15%. If you're really specific, change gear ratios. If you really want to win, dump water in the dangerous competitors' tanks...eheh
Old Jan 18, 2001 | 06:08 PM
SandmanBlue's Avatar
No. The reason being is that "really fast" and "ds650" can't be used in the same sentence without laughter coming from anyone that ownes a Banshee...
Old Jan 18, 2001 | 06:59 PM
sik_banshee's Avatar
A DS with a pipe will slightly beat a piped banshee in top-end speed on the flat. I know. I lost.
Old Jan 20, 2001 | 02:32 PM
300exSTER's Avatar
a ds650 with : High compression piston, 3 angle valve job, porting, cam's, carb, (maybe big bore), tires and ignition removed would sure smoke its share of banshees. I know those banshee's FLY when they are modded up, but give the ds some credit. ANd if your going to post something stupid to make pepole mad, dont even bother.
ryan
650cc ds
Old Jan 21, 2001 | 09:24 PM
ScoobyDFW's Avatar
100HP Turbo/EFI DS650
MRDS650
Feb 22, 2026 11:26 AM
Sep 29, 2015 09:35 AM
MooseHenden
Polls
33
Aug 28, 2015 04:56 PM
HYS
Aug 18, 2015 12:28 PM
Jul 24, 2015 11:57 AM
