Dunes and Dune Machines Discussion on dunes and dune machines.
A sand virgin here, I got a few ?'s...
Old Apr 8, 2002 | 10:08 AM
BG400's Avatar
Hey guys,
Im making my 1st trip to some dunes this weekend. I have never rode or been around sand with my quad yet. Is there any special prepping I need to do to my bike? I have heard that everything needs to be free of grease, like your chain, bushings, etc. Is this true? I dont own or have access to any paddle tires, so it looks like I will be running Razrs this weekend. Will these tires carry me around the dunes ok? Any other info you guys can share with a newcomer would be greatly appreciated. Thanks!
Old Apr 8, 2002 | 11:49 AM
Mike330R's Avatar
If you have any grease on your quad the sand will just stick easier. Might wear the chain a small amount faster.
Your tires will work fine just air them down to about 3-4 pounds.
Have fun!
Old Apr 8, 2002 | 12:35 PM
THEMOOSE's Avatar
Grease your quad just clean off any extra that gets by the seals & when you get back regrease all fittings to force out any sand that may have got past your seals.
You don't want to use oil or a sticky lube on your chain but you don't want to leave it dry either, use a dry lube.
wash your quad to remove all sand regrease all fittings & relube chain you'll be OK.
you may struggle a bit with the Razers but it won't stop you from having fun. If you enjoy the sand invest in a good set of paddles like Extreme haulers (great forward traction for drag racing & hillclimbs but harder turning) Or angled paddles (fair forward traction good turning ability).
Have fun, Ride safe & be warned sand is addictive!!
Old Apr 8, 2002 | 06:16 PM
WyoDuner's Avatar
Which dunes are you going to???
Old Apr 8, 2002 | 07:05 PM
BG400's Avatar
I dont know the name of the place, it is somewhere in Ohio. The poeple im going with know the info, Im just a follower.
black_thunder
Sep 20, 2015 10:21 PM
rawbdiggity
Sep 7, 2015 12:05 PM
lancemll88
Sep 5, 2015 03:16 AM
Jul 24, 2015 11:57 AM
