Dunes and Dune Machines Discussion on dunes and dune machines.
Modified Blaster vs. Stock 400 EX
Old Jul 19, 2002 | 04:40 PM
YFZRacer's Avatar
Who do you think would win in the dunes me on My Blaster or a Stock 400EX. Take into consideration that i am only 100 pounds and with a 200 pound rider i have a 150 pound weight advantage. So with my Toomey Pipes i have 25hp check the website if you don't believe me. And a 400EX has about 27. So using those specs i have a much bettter Power to weight ratio. And in the dunes that is very important.
Old Jul 20, 2002 | 03:38 AM
kciH's Avatar
You do have an overall power advantage against a 400EX in the sand when you take the weight factor into account. I think you'll do well against a stock one, but beware you don't overheat your machine because there is a very heavy load placed on your machine when riding in the sand. If your "high flow" air filter is a K&N make sure you at least have a prefilter on it. Whatever it is, make sure it is cleaned regularly and oiled properly because this will make your engine live much longer. If you are going to a area away from home where it is much warmer than in Alberta, be prepared to rejet. You may want to rejet to run in the sand because you will be running at wide open throttle much more so than in the dirt.
Old Jul 20, 2002 | 12:51 PM
YFZRacer's Avatar
Thanks for replying. And finaly i found someone who thinks i would do good in the dunes against a 400EX no seemed to believe me at atvnews forum. And ya its acually not a K&N air filter its what comes with the toomey kit. Its like a 2stage foam airfilter. I i'm going to find and outerwhere to put over the air box lid to let lots of air in but keep some of the crap out. I'm not sure if they make one for the blaster but i do know they make one for my dad's raptor and it worked good. So i might just have to improvise to get something to work. Ya the dunes i go to are in Alberta but i'd really like to go to somewhere in the states to the biggers sanddunes. That would be lots of fun!!
Thanks again for replying!! What do you drive a trike?
Old Jul 20, 2002 | 01:32 PM
kciH's Avatar
I ride a trike. 85 ATC250R with a 350 powervalve jug and all the goodies that go along with it. I've got a couple of other trikes also, but I mainly ride a 01 YZF426 dirtbike.
I'll bet with your newfound power that you would like one of the 03 blasters with full hydraulic disc brakes front and rear! The faster it goes the longer it takes to slow down.
Old Jul 20, 2002 | 02:38 PM
YFZRacer's Avatar
Ya i'm glad they finaly did that mod on a blaster thats what everyone seems to complain about. But i don't think i'll buy it instead i wait and in a couple years get a banshee or someother high performance quad. And i bet you'd like the new YZ450.
Old Jul 20, 2002 | 02:49 PM
kciH's Avatar
I'll let you know about that when I put one in my garage in the spring.
Old Jul 20, 2002 | 11:49 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
HEY toomey tell this to your friends with my 200 lbs butt on my friends sons
blaster with toomey's. i kick his twelve year old sons butt on my 2002 400ex stock and the little fart only weighs like 75 lbs. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 21, 2002 | 12:42 AM
YFZRacer's Avatar
Awesome that's what i've been trying to tell ppl but no one beleives me. And even with only a 25lb advantage. THANKS FOR THE INFORMATION!! Take that 400EX owners!!! no offence azsand
Old Jul 21, 2002 | 01:16 AM
YFZRacer's Avatar
I screwed up on the weight thing there i ment to say the 400EX had a 75lb weight advantage over the blaster and the blaster still won awesome!!!!!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 23, 2003 | 08:06 PM
400ex5500's Avatar
Default Modified Blaster vs. Stock 400 EX
I'll race you any day on my stock 400ex and win
y r all the blaster people think that blaster will out run 400ex
keep on dreaming
