Dunes and Dune Machines Discussion on dunes and dune machines.
Paddles?
Old Oct 9, 2002 | 01:05 AM
SomeCrazyMexican's Avatar
Default Paddles?
Just wondering what kind of haulers would be best for my banshee? All the mods I have are listed below. Would the 20x10x10 8 paddles work or the 22x11x10 8 paddles? Just want to know what haulers are best at picking up great speed and traction with all my mods?
Old Oct 9, 2002 | 01:57 AM
THEMOOSE's Avatar
Default Paddles?
I'd go with the 8 paddle 22x11x10 in the Extreme Haulers.
Old Oct 9, 2002 | 04:05 PM
WyoDuner's Avatar
Default Paddles?
Yep, what moose said.
Old Oct 10, 2002 | 01:25 AM
Default Paddles?
The taller the tire the better the hookup right?
Old Oct 10, 2002 | 10:39 AM
THEMOOSE's Avatar
Default Paddles?
The taller tire changes your final drive ratio.
Since there is a lot of tire spinning going on in the sand the taller tire spins a little less & so it does help with hook up.
Going taller than you need or using too many paddles will cause you too much hook & cause bogging or suck up a lot of power on top.
Old Oct 10, 2002 | 11:52 AM
rzcolobanshee's Avatar
Default Paddles?
Go 22x11x10 with 10 paddles. You will regret getting 8. I had the same mods as you...actually a little less and 10 paddles were almost not enough, i still spun the hell out of them.
Old Oct 10, 2002 | 12:58 PM
WyoDuner's Avatar
Default Paddles?
10 paddles do hook up better - we have similar mods - but I find that the 8 paddles don't drag me down as much on top. I have a set of 10 paddle haulers and I prefer the 8 paddles. If you ride where you can really open it up into 5th or 6th you will see the difference in drag.
Old Oct 10, 2002 | 01:12 PM
THEMOOSE's Avatar
Default Paddles?
Thats true!
I tried a set of 10 paddle tires & they hooked up good but they really drag you down on the top end.
I lost a couple of hundredths of a second in my 60 ft times with the 8 paddles but gained a couple of tenths in 100 yards cause it could rev out better.
Unless you go big bore or a radical port job stick with the 8 paddles. JMO
Old Oct 10, 2002 | 05:06 PM
Default Paddles?
More than likely I am going to go with the 8 paddles but im still not so sure on the size of tire, if I get a 10 in tire and the stock size is 9, will I have to have differant hubs for the back axle?
Old Oct 10, 2002 | 07:11 PM
THEMOOSE's Avatar
Default Paddles?
No you won't need a diffrent hub but you will need 10" wheels.
