Dunes and Dune Machines Discussion on dunes and dune machines.
sand tire pressure
Old Dec 18, 2002 | 02:58 PM
BDL's Avatar
BDL
Default sand tire pressure
What amount of pressure do ya'll use on your sand tires?
Old Dec 18, 2002 | 05:23 PM
SCOOT400EX's Avatar
I have sand sharks and run 8-9 psi.
Old Dec 18, 2002 | 08:19 PM
chad400ex's Avatar
Geckos in back....about 2.5 psi
Dune Trackers up front.....about 5 psi
Old Dec 19, 2002 | 04:36 PM
Rudedog's Avatar
Rears: 2.5 psi to 5.0 PSI
Fronts: 5 psi.
Rude Dog
Old Dec 19, 2002 | 05:07 PM
RacinJason's Avatar
front 6psi
rr 5 psi
These settings are not for hill racing, but for jumping, I have had problems keeping my rear tires beaded up at lower pressure and once you loose a bead in the sand it hell to get it to seal back up without catching small grains in the bead allowing them to leak down
BRAAAP
Old Dec 19, 2002 | 07:39 PM
Ward660R's Avatar
I ran about five in my Sand Sharks.
Old Dec 19, 2002 | 10:29 PM
SCOOT400EX's Avatar
Hey do you guys think I might be running a little to much air in my sand sharks? Please let me know thanks
Old Dec 20, 2002 | 02:13 AM
Slacker1bob's Avatar
Yes you are. 3-5 pounds is all you need in the sand
Old Dec 20, 2002 | 08:15 AM
Ward660R's Avatar
I agree too, that is if you want traction. I can't beleive you can start with 9 lbs in them without getting stuck. I have tried it before and if you just want to sling the rear end around its fun.
Old Dec 23, 2002 | 04:11 PM
TriRap's Avatar
Extremes 5psi
