best paddles for trailblazer 400
I am wanting to get some paddles for my trailblazer.I mostly just ride the dunes and jump. What size would be best and is there a tire and wheel package that i can get.
If you want a good tire that's cheap and a straight blade the kenda dune runner 22/11/10 8 paddle will do fine. If your stock or slightly modded 8 paddles will be enough. If you want a little better tire you can go with the skat trak hauler or extreme hauler, but limit them to 8 paddles
Because if you don't have enough power to get them going, they will cause you to bog down and hurt you on the top end. If you are stock 8 paddles will be plenty. I have a trail mod setup that I run 8 paddles on and a racemod 70+ horsepower that I run 10 paddles on. You've got to get them spinning to the hp and pvt going.
I have not used the kenda dune runner 22/11/10 but in my opinion, like polarisfreak said, The skat track haulers in an 8 paddle 22/11/10 are about the beat tire for your money. I have used sand skate II, paddle masters, kenda dune trackers and I like the Hauler the best BY FAR.
The haulers seem to float accross the sand where the others just dig down. They are also very light, and lets face it POLARIS machines don't need any help more weight.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
