Paiute Trail, Utah
Old Apr 19, 2019 | 09:36 AM
  #1321
Specta's Avatar
Its that time of year to start doing some spring cleaning so I started with the trail closest to me.
This section of trail was closed few years ago with a new section bypassing this section.
It looks like someone has ridden thru it any way. I'd guess because they couldn't get passed the snow that was on the trail.
So I drug a big tree to close it off.
We got tons of snow this winter. Last year at this same time there was nothing here.
This is 4 miles from my place.
I under estimated how much throttle I needed. LOL
This was at the top of the section that is closed. I decided to block it off too.
I guess I used my winch too much. It was sitting there idling while I was putting
my chain and ****** block back in my trunk and the engine revved up on its own and died.
The battery died and it wouldn't start. ​​​​​​​ ​​​​​​​​​​​​​​
Once again I was fortunate to have cell service and called my buddy to once again come and rescue me.
We jumped it and it fired right up. Once it was running I finished dragging another tree across the trail.
The End.
Old Apr 19, 2019 | 12:19 PM
  #1322
Beautiful pics, Specta.
Man, that BF is already about 100x less reliable than your old Rubicon was.
Is this the section of the 01 near the park you live in?
Old Apr 19, 2019 | 03:20 PM
  #1323
Specta's Avatar
I think I over worked the winch and battery.
Yep, its the 01 just east of me.
Old Apr 19, 2019 | 06:23 PM
  #1324
Specta's Avatar
I'm blaming it on the Warn Winch. This is the second time this has happened to me.
Battery is less than one year old. AGM rated at 220 CCA. More than the OE battery.
I never had this problem with my KFI.
Old Apr 20, 2019 | 10:05 AM
  #1325
That's a big reason I like the Can-Am Outlander XTP I had and the present one. They both had high output magnetos. Never had battery issues with either and I've done a lot of winching. Especially plowing where I'm raising and lowering the blade dozens of times per storm.
Old Apr 20, 2019 | 11:43 AM
  #1326
Specta's Avatar
Kawasaki puts out 30 amps. I would think that should keep up with it.
Old Apr 22, 2019 | 02:23 PM
  #1327
I think mine has 65 watts. Nice to know I probably won't ever need the full amount.
Old Apr 23, 2019 | 01:18 AM
  #1328
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
If that's 65 amps, that's a lot of amps. That equals 780 watts at 12 volts or 910 watts at 14 volts. My owner's manual says my alternator puts out 350 watts. That's 29.2 amps at 12 volts or an even 25 amps at 14 volts. If mine is 25 amps and yours it 65 that's a HUGE difference. I don't know what the voltage at the winch actually is or how many amps it uses but I never had a problem with any of my Warn or Polaris winches drawing down the battery as long as the engine was running.
Old May 2, 2019 | 07:54 PM
  #1329
Specta's Avatar
Old May 3, 2019 | 05:57 AM
  #1330
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
Was the duck swimming on the trail?
I had fish swimming around my van once. Don't ask, I've been trying to forget about it since I got pulled out. The exhaust bubbles were like a trout Jacuzzi in the middle of the forest. What the h___?
