Honda 350 es
Old Oct 11, 2009 | 06:45 PM
bigJMS60's Avatar
Default Honda 350 es
I have a honda 350 es .gas pouring out of vent pipe on bottom of carb.took top off of carb and removed needle valve.sprayed carb cleaner in hole were needle valve was.put back together turned on gas ..gas still pouring.when i took out the air filter the air filter box was full of gas also..help
Old Oct 12, 2009 | 05:24 AM
HondaMechanic's Avatar
The carb will have to be removed and cleaned , the inlet needle checked for wear the inlet needle seat checked , the float & float pin checked ..
Myself I have several old 1L oil jugs & 4L anti-freeze jugs cut off and cleaned ..I dis-assemble the carb putting jets , emultion tube , float & needle etc in 1 of the oil jugs , and I put the carb body in an anti-freeze jug (after removing all rubber hoses ,o'rings etc) I fill both containers with carb cleaner and let set 1 day .. The Honda carb cleaner isn't cheap but over the years I've saved several gallons from carbs cleaned .. I save it by using 1 new can with every carb cleaned (the customer gets charged for 1 can carb cleaner) ..
We've tried several brands of carb cleaner and found that the Honda carb cleaner is 1 of the best working , jets and all brass parts come out shiny looking like new .. The aluminum carb body if left in carb cleaner to long will start turning blackish color so don't leave it soak to long ..
When you remove the carb parts clean them with contact cleaner and air especially holes like pilot screw hole , vent line holes etc ..
That is the only proper way to clean a carb ..
I've seen on forums that some people use wire like oxy/ace welding tip cleaners etc to clean jets .. Once you push a steel wire thru a brass jet then your 120/42 jets (or 128/42 jets on 2004-06 TRX350) is no longer 120/42 .. I have Honda wire jet cleaners made for power products but I don't even use those on power product carbs for the same reason ..
Old Oct 21, 2009 | 07:43 PM
bigJMS60's Avatar
Thanks for the help/took carb off cleaned real good put back on everything fine thanks again..bigjms
Old Oct 21, 2009 | 07:53 PM
bigJMS60's Avatar
Angry Polaris 500 sportsman
ITS ME AGAIN .MY 5OO POLARIS FRONT SEAL WENT BAD ALSO THREE OUT OF 4 BEARINGS/REPLACED SEALS AND BEARINGS .WHEN I DRIVE ATV ON PAVEMENT THE FRONT END SHAKES.IVE TAKEN THE FRONT END APART THREE TIMES .CHECKED DRIVE SHAFT TO SEE IF JOINTS WERE BAD .COULD IT BE THE TIE ROD ENDS?HOW MUCH PLAY SHOULD THE TIE ROD ENDS HAVE ?
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
