Plowing question.
Old Nov 30, 2009 | 12:39 PM
ATPmike's Avatar
Default Plowing question.
Hello.. I just picked up a Glacier 1 plow set up for my ATP. I was wondering if everyone uses the skid feet that comes with the plow. I never used them before. Should I use them?
Old Nov 30, 2009 | 12:46 PM
DODGE57HEMI's Avatar
Mopar Man!
Ya I used to use mine with a 1/4in of ground clearance for paved parking lots on a Polaris 600 twin.
Old Nov 30, 2009 | 01:10 PM
trinityquad's Avatar
Default Use the skids
Yep, use mine set for 1 to 1 1/2 inch because of gravel drive and uneven ground. No point in plowing up gravel that cost $ and back pain to put in. The ground here is so uneven that even with the plow all the way up the skids touch the ground where my drive hits the road.
Basic rule for road maintenance is 3/4 inch clearance from surface.
Old Nov 30, 2009 | 01:21 PM
Mopar Man!
**NOTE** I also put a bead od weld on the blade to make the edge last longer.
Old Nov 30, 2009 | 05:34 PM
user493's Avatar
Moto Psycho
Absolutely use them. My driveway is concrete and I set the skids so they're even with the blade. It makes the blade last for years. On a brand new plow I actually set it so the skids aren't quite touching. The blade soon grinds to be perfecly even with the skids.
Old Dec 13, 2009 | 10:56 AM
ATPmike's Avatar
Just an update: I took everyone's advice and I am using them. I have plowed twice so far and it is working out very good. I set them so the blade is barely off the ground. Just wanted to thank everyone. Thank You.
Old Dec 13, 2009 | 12:54 PM
mudslinginfool's Avatar
Does it in the Mud!
i used to use them but they wore out then broke and fell off. I decided not to use them anymore. the blade still has plent of wear on it and a new steel piece is only 20-30 bucks at home depot. cheaper than buying new skidders that arent going to last as long. I dont plow a whole lot though,since all the snow tends to go around st.louis.
Old Dec 18, 2009 | 09:31 PM
chuck_raduenz's Avatar
i built my plow. i never added skids/feet to them. i have a 1/4 x 4" wear bar on mine. this will be my second winter useing it to plow other driveways. i used my plow on aprox 3 places. for a total of about 20times ish. on concreat driveways about 3 cars long avg. so far its wore off 1/4" of the wear bar. not bad. evon tho i think 1/8" of it was tell it wore to the angle of the driveway to get the square edge off.
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
