polaris tow hook
Old Jun 14, 2010 | 02:13 AM
codyspratt's Avatar
Default polaris tow hook
where are you SOPOSE to hook to to pull out a stuck 00 sporsman 500 4x4 at ??? is it the 2 small loop like holes on each side at the botom of the grill ???? looks as if they would pull out or bend.. does ANYONE make a front tow hook for them ??
thefuzz65@yahoo.com
thanks
Old Jun 15, 2010 | 11:35 PM
chuck_raduenz's Avatar
i wouldnt trust them loops. polaris dose make a bolt in tow hook up a bit higher between the bottom of the raidaitor grill and the tow loops. it bolts in the 2 holes. i did buy my loop i made one.
Old Jun 16, 2010 | 01:13 AM
codyspratt's Avatar
how did you make one ??
Old Jun 16, 2010 | 01:23 AM
i took 4 bolts. i cut the heads off of 2 of them added a nut to the bolt. put it in the holes and added another nut on the other side. i then cut the head and threads off off 2 more bolts and welded them like a triangle. think i have pics ill have to look for them. or you could also use ready rod. or just spend about $50 and buy one from polaris. i was too cheap at the time. but it worked.
Cole Hadden
Jun 15, 2025 09:05 AM
TheHood
Aug 8, 2015 05:49 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
toonces
Jul 11, 2015 12:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
