Best Synthetic 2 Stroke Oils?
Old Sep 7, 2010 | 08:23 PM
PinkFloydEffect's Avatar
Originally Posted by sdm111
I know a bunch of people that swear by type F ATF, in 2 strokes that is.
Is that what YOU run? And tranny only right? As gear oil?
Originally Posted by ddenleyy88
I have run Mobil1 2 stroke full synthetic Castor927 and some of the Klotz oils and never had a problem
It's not about having a problem, it's about what is the best! And I did not even know Mobil1 made a fully synthetic 2stroke mix, I've only used the 4T
Old Sep 20, 2010 | 08:59 PM
Question
I was talking to the guy at the auto parts store today about purchasing large quantity's of gas mix oil. He said buy a gallon of outboard motor oil and the only difference is that it has something in it to make it more environment friendly since it exausts into the water. Is this true is it ok to run this oil? If so why isin't ALL mix oil enviormental friendly like this does it make it cheaper? Or will this stuff not perform the same in a motor not on a boat? My friend burns some sort of performace mix oil that makes the exaust smell like RC car fuel when I ride behind him it's weird.
On another note, 93 octane is the highest available at gas stations so that is what I run however I see all these octane boosting formulas out there, so what is the highest you can run your engine at or what is the BEST octane rating to have your gas on a 2 stroke engine? Higher is better but only to a certain point right?
Old Sep 24, 2010 | 10:48 PM
MECHANIKE's Avatar
you only need high octane if your running high compression (over 11to1)to prevent spark knock because of a differant flash point.octane boosters only bring it up half a point if that.if you really needed high octane,if you can find 108+leaded racing fuel or even aviation fuel and mix 8 to 1,,,,,,,,,,,,,,,,
Old May 30, 2012 | 10:53 PM
Old thread but, can anyone double verify the risks or downsides in using outboard 2 stroke boat mix oil in our 2 stroke bikes and quads?
Old May 31, 2012 | 07:23 AM
  #15
TacticalRedneckofKentucky's Avatar
I use klotz and ams oil race mix in my weedeater..... ....
Old Jun 3, 2012 | 06:32 PM
  #16
Raven95150's Avatar
I just use the cheap 2 stroke oil I get in 2 gallon jugs at Fleet Farm. It has TCW3 rating, which means it's rated for use in outboards. I've been using it for years in everything from chainsaws and trimmers to snowmobiles and ATVs. Unless you have a super high performance engine with special requirements, I see no reason to waste money on overpriced synthetic 2 stroke oil that just gets burned up.
Old Jun 3, 2012 | 06:41 PM
  #17
That's what I'm thinking but why would better oil for the environmental be cheaper? I'm curious on the real break down here
Old Jul 10, 2012 | 08:30 PM
  #18
Corno's Avatar
Default Best 2 stroke oil
Originally Posted by PinkFloydEffect
Who makes the best synthetic oil for 2 strokes? Engine/tranny oil and premix oil?
I use Mobil1 Racing 4T 10-40w in my four strokes, but the best stuff they sell for 2 strokes where I work (CAP) is Castrol 2T Motocycle Oil at half the price I payed for the Mobile1 4T. I am using it in my lt250r quad racer, all 2 stroke oil is the same right, weight wise?
I am a true believer in the Amsoil products. They make great products that give you peace of mind knowing your motor will last.
Old Jul 17, 2012 | 11:58 PM
  #19
truckboy1's Avatar
Amsoil is best for 2 stroke engine gives outstanding film strength and lubricity.
Old Jul 18, 2012 | 10:33 AM
  #20
Even when burned?
