Wheel & Tire combination to avoid wheel damage
Old May 3, 2011 | 08:20 AM
cncpro's Avatar
Default Wheel & Tire combination to avoid wheel damage
Hey everybody,
After putting 500 miles on my new King Quad 750 I am learning that I am apparently pretty hard on it.
The rear wheels are taking a beating to the point that I had to hammer out a big dent last night because I was afraid the bead would pop while riding
Also noticed that the stock Dunlops are showing some pretty rapid signs of wear so I'm starting to formulate a plan for new tires and wheels in 4 or 5 months...
Is there something I can do to make the wheels better protected by the tire ? Maybe like using a narrow wheel with a wide tire so the rubber can protect the wheel better ?
Getting a lot of recommendations for Bighorn tires... Maybe a tire like that would protect the wheel better anyway
Any advice would be appreciated. Thanks.
Old May 3, 2011 | 09:45 AM
If you go with a wider tire on your stock rims or rims with the same setbacks and width of your stockers it will protect the rim better as you thought. I noticed a pretty good difference when I went to Mudlite XTRs. The rims are much better protected now.
Old May 3, 2011 | 01:17 PM
cncpro's Avatar
Thanks for the help Moose.
Old May 3, 2011 | 03:04 PM
wilson911's Avatar
First of all, when you replace, you will want to get a tire taller than your stocks. Basically go as tall as you can without adding a lift kit. This will give your rims more cushion when you are bouncing off the rocks and stumps. I went up two inches from stock and it makes all the difference in the world!
Be careful going too wide. It might not seem it, but a couple inches sticking out on each side can make you more vulnerable to sidewall damage. So yeah, you are protecting your rims but slashing a sidewall will leave you stranded. Especially on our NE trails with tight trees and gates.
It costs extra, but ITP rims are indestructable. You can even get them fancy ones with the beadlock on it. And, they have lifetime warranty. You can't beat that.
I got an an extra set of 12" stock rims that may fit that KQ if you need them until you buy something else.
Old May 3, 2011 | 07:20 PM
cncpro's Avatar
Thanks Wilson,
I had thought about going larger but that will prevent me from using the tire chains because they're already too close for comfort. I guess that's a sacrifice I could make but they really were helpful in the deeper snow...
Great to know about the ITP rims. Does that warranty actually cover damage from slamming rocks ? If so that sounds very helpful.
Old May 3, 2011 | 07:31 PM
wilson911's Avatar
Originally Posted by cncpro
Thanks Wilson,
When you get a replacement set, you can set up your stock wheels/tires with the chains on them and use them strictly for snow. I thought about doing this with a set of stock for mine.
ITP's warranty covers pretty much everything. If a rim breaks or bends, they will replace it.
Old May 3, 2011 | 07:37 PM
cncpro's Avatar
That's a smart idea. I guess I have my plan. Now I just gotta make a few extra bucks to finance this damned addiction.
STLyamwar
Jul 25, 2020 04:44 AM
Jul 24, 2015 11:57 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Jul 21, 2015 03:03 PM
rcappie4
Jul 18, 2015 07:51 AM
