auto or semi manual?
Old Sep 28, 2011 | 06:52 AM
jay929rr's Avatar
Default auto or semi manual?
I see that suzuki and yamaha have atvs with semi manual, how does that work exactly? i was set on getting an auto but this caught my interest.
Old Sep 28, 2011 | 07:07 AM
Semi automatic transmissions on quads use a foot shifter to switch through the gears. Usually, lifting up a click at a time to shift up and down to shift down. Unlike a manual transmission on a sport quad or MX bike that requires you to pull in a clutch lever. It's pretty easy to use. The only weird part is usually reverse. You have to do some combination of shifting down with the foot shifter and turning a **** or pushing a button at the same time. I guess it's kind of a safety feature so you don't inadvertantly shift down into reverse.
Old Sep 28, 2011 | 08:47 AM
TLC's Avatar
TLC
In lame mans terms a semi Auto is like shifting a motorcycle but with no need to use a hand clutch and it will not move at idle even in gear.
The Automatic ATVs are like a Snowmiles but with wheels, you just gas and go. 90% of utility ATVs are Automatic. There nice because there is no worrying if your in the right gear for the trail condition like climbing a hill.
Most Autos do have a low range option for hard going low speed conditions such as pulling/pushing a load or being burried in Mud and such.
Old Sep 28, 2011 | 02:29 PM
jay929rr's Avatar
oh okay thanks, i actually rented an atv a long time ago that shifted the same way. I can't believe they can shift without pulling in a clutch first.
Old Sep 29, 2011 | 12:50 PM
DogRunner2's Avatar
Honda has the option of both on the same atv.
Old Sep 29, 2011 | 02:23 PM
jay929rr's Avatar
its seems like the hondas don't have as much ground clearence. I would think i would want at least 9.5 inches for mudding. agree or no?
Old Sep 29, 2011 | 02:44 PM
In mud, the more ground clearance the better. The lower you go the more you are plowing instead of clearing.
Old Sep 29, 2011 | 02:58 PM
TLC's Avatar
TLC
You can,t get much Ground clearance from a Straigh Rear Axle,(SRA) the rear diff is always the lowest part of those ATV plus it rides rougher than a Independent Rear Suspension (IRS) ATV over bumps and there alot of bumps out on the trail.
Thats why most ATVs are IRS now. It would take a SRA ATV with 27" tires to have the clearance of a IRS ATV with stock 25" tires.
Get IRS, your back and rear end will love you for it after mile 10.
SRA
IRS
IRS over rough ground. Lets see a SRA do this.
Old Sep 29, 2011 | 04:53 PM
user493's Avatar
Moto Psycho
I owned a SRA quad for about a year and after riding an IRS I never want another SRA. I like the automatic transmission better too. I'll always buy something like a Sportsman or Grizzly. I don't have any use for a sport quad because I use my quad for plowing snow.
Old Sep 29, 2011 | 06:49 PM
jay929rr's Avatar
sweet. i surprised the honda foreman doesn't have the irs. i guess its more for hauling and trail riding not mudding as much.
